Idle code
Idle code
I may have imagined this, but i thought i saw someone say they were writing a new type of idle code to allow a constant VE at idle.
It worked something like if TPS < setpoint and RPM < setpoint then VE = XXX.
Was it ever made, I can't find anything about it..
thanks
andrew
thanks
andrew
Idle code
Why don't you make all the ve bins around the idle point the same. Works for me...
SFC
SFC
Posted by email.----- Original Message -----
To: megasquirt-mss@msefi.com (megasquirt-mss@msefi.com)
Sent: Monday, May 22, 2006 12:53 PM
Subject: Idle code
Yeah that would be cool.. How hard would it be to implement?
I'm using 026h4 or h8, not sure.. is it just a matter of pasting in custom code or is there more to it?
andrew
This post is at: http://www.msefi.com/viewtopic.php?p=121478#121478
You need to edit the .ASM file where the vecurr is calculated and either use that or substitute it for a VE value of choice. You also need to edit the .ini and create a menu for it to input all the variables.
With my code it waits until it`s in idle-mode before locking the VE but you could use a tps-threshold value instead, along with MAP, Coolant and RPM.
If you upgrade to 029Q it`d be easier for me as I`m all set up for that on the computer, still posible on the 026 though.
Squirted VW GTI 16vG60 mk2
Keithmac
I just did some searching and found you posted your version of the code here;
http://www.msefi.com/viewtopic.php?p=10 ... dle#109542
This appears to have everything i need, should i just try that one to save you having to do any work for me?
How does your code define 'idle mode'? Under what conditions does it lock the VE? Is it just under 1300 rpm, or is there more to it?
andrew
andrew
You can give it a go but I`m running a newer version, it would be interesting to see if you have any success with it.
Idle mode comes in after the car has fired the Idlevalve into action only with the tps below threshold, turns on idle timing control and idle VE lock, the idle valve control code is also different. The moment the throttle is pressed it comes out of VE lock and idle timing adjustment.
I`ve re-jigged the startup code since, and added idle specific O2 settings as well.
If you don`t have any joy with that one I`ll post my latest one up for you to have a try.
Idle valve is given a cold starting DC, code runs from the turn of the key adding 300 rpm to idle target value for the start timer, idle then drops to target, igntion control active thoughout.
The code is reliant on TPS settings, if you do use it use Tools/ Review Mode in MT and check everything before you start it up. (especially the Idle menu).
Keithmac,
Been out driving quite a bit today and i have a great smooooth idle..
There is, however, a problem. When trying to pull from low rpm, the car bogs down. This happens pulling away from lights, in carparks, at roundabouts etc. The car just goes dead, and occasionally pops through the inlet. What i assume is happening is that it is stuck in 'idle mode' until 1300 or so rpm. My hot idle is about 950 leaves about 350 rpm dead.
What would be ideal is if the tps went over a threshold, say 7% (i idle at 5%) then it would switch off idle mode.. Is there anything like this in the code, and what other settings could i try changing to rectify this? At the moment i can put my foot flat to the floor and nothing will happen..
The idle itself is 99% perfect, so i'd like to sort out how to make it more drivable, i'v been doing 'boy racer' starts!! I'm using most of the default settings that came with the code..
thanks
andrew
thanks
andrew
This is the idleVE code,
" lda RPM
cmp #13T ;1300 rpm limit (failsafe)
bls IdleVE
mov tmp6,vecurr
rts
IdleVE: brset idleadvance,idlebits,IdleVE_YES
mov tmp6,vecurr ; Normal Table..
rts
IdleVE_YES:
lda idleVE_f
sta vecurr
rts "
It all hinges on the idleadvance bit which is set when the TPS is under threshold, it sounds like the code is not reacting with your tps properly or the threshold is too high?
Also the idle code will stay open until 2000 rpm with my settings, you can adjust the rpm where it closes in the first idle menu, I made the rpm delay because while holding the revs to set off in mine as the valve closed it dropped the engine revs which made seeting off tricky.
Do you see the VE in megatune change from the fixed ve to table ve as you press the throttle?
I`m runnning an idle switch rather than tps so this could alter thing slightly, if you have no joy with altering the TPS thresholds give me a message back.
I`ve got a later code runnning in 029Q, and one in the 029Q2-v5hi-res injector as well so I`ll post these up.
Just checked my later code and I`ve added a MAP threshold to idleVE lock so that should sort the flooring it from idle problem, but it should switch off anyway?
I`m on a stag do `till Sunday so I`ll post one up then
" lda RPM
bls IdleVE
mov tmp6,vecurr
rts
rts
IdleVE_YES:
lda idleVE_f
sta vecurr
rts "
I've tried tps ADC values of 0, 1, 35, 36, 40, 90.. at idle mine is 35. It seems to barely make a difference. The VE just sticks at the idle value.
At idle, when you press the throttle the accel enrichments lifts the revs to 1300 and it swiches and revs as expected. If you press the throttle slowly, it is possible to stall the car as the AE doesn't trigger, it lean out and stops.
Under load (for example 4th gear driving) i can floor it and the VE stays at my idle VE, doesn't switch back to the table.
So as you say it seems to be an issue with how my tps works with the code.. What can you suggest to try?
thanks
andrew
thanks
andrew
