car dies near 3k rpm
hi guys here is my problem i was using my ms1ns-e to control only the fuel and the car rev fast and idle now im using the spark control and when the car is near the 3k the car dies im using a 4 pin module to conditining the signal from the vr sensor and a msd to drive the coil any suggestion in what should i try. is a v2.2 board code 029q2 and megatune 2.25 and everything hook up like this from the vr sensor + to W in the 4 pin from - of the vr sensor to G a 470 ohms 1/2 w resistor from B to C B is 12 volt and C to pin 24 in megasquirt im using fidle for spark since idont have one and from fidle to the white wire of the msd and now when the car is near the 3k rpm the car dies any idea in what could cause this.thanks
Re: car dies near 3k rpm
elturbonitroso wrote:hi guys here is my problem i was using my ms1ns-e to control only the fuel and the car rev fast and idle now im using the spark control and when the car is near the 3k the car dies im using a 4 pin module to conditining the signal from the vr sensor and a msd to drive the coil any suggestion in what should i try. is a v2.2 board code 029q2 and megatune 2.25 and everything hook up like this from the vr sensor + to W in the 4 pin from - of the vr sensor to G a 470 ohms 1/2 w resistor from B to C B is 12 volt and C to pin 24 in megasquirt im using fidle for spark since idont have one and from fidle to the white wire of the msd and now when the car is near the 3k rpm the car dies any idea in what could cause this.thanks
Please post your MSQ as well as a datalog of when the problem occurs.
Thank you.
Use the "Browse" then "Add attachment" just above the "Preview" and "Submit" buttons when posting.
lets try this one its different one and a log.
Last edited by elturbonitroso on Fri May 26, 2006 12:27 pm, edited 3 times in total.
We still don't have your MSQ
i took the car out of the garage for a little spin and this is what happen when i go slow in the throttle the car stutter and i press the pedal more and nothing the car die i hear the relays.turn on the car in neutral i rev the car and rev but it makes like a litte stop near the 3k what sould i try to work on.
So you don't have fuel pressure hooked up to your Megasquirt?elturbonitroso wrote:scott where in the log you see fuel pressure.
You must have it enabled in your .ini and it is reading something off X7. The default has this field turned off. you would have had to go in and remove the semi-colon for this to log.
Code: Select all
[Datalog]
; entry = fuelpress, "Fuel Press", int, "%d"
You know it just looks like you need to tune it, read the tuning section of the Megamanual.
http://www.megamanual.com/v22manual/mtune.htm
I looked at the log last night and what I thought I was seeing was this:
engine starts and idles ok. Blip throttle and raise rpm to 2000-3000, release throttle, engine rpms drop and then suddenly fall to zero.
Is this what happens in practice? It is the sudden 600rpm then 0rpm that looks odd - almost as if the tach signal failed.
