LED 18 does not flash on firmware 029q2
I'm using LED 17 for spark output and LED 18 for IRQ Triger using distributor mode and MSD Ignition. The middle led flash and the injectors pulse but the right led remains on and the ignition does not spark. I am really frustrated with this. I'm using a Bosh Hall Sensor with 4 windows on it and the engine is a 1.8 VW 16V from a Jetta 88.
Any Idea?
Any Idea?
LED18 is the middle LED. Does it flash or not? In the subject you say it doesn't but the message you say it does.
Do you get rpm in Megatune?
Please post your MSQ so we can examine your settings.
<?xml version="1.0" encoding="ISO-8859-1"?>
<msq xmlns="http://www.msefi.com/:msq">
<bibliography author="MegaTune 2.25 beta" writeDate="2006-01-20T00:27:05-05:00" />
<versionInfo fileFormat="4.0" nPages="8" signature="MSnS-extra format 024s *********" />
<page number="0" size="200">
<constant name="algorithm1">"Speed Density"</constant>
<constant name="alternate1">"Simultaneous"</constant>
<constant name="baroCorr1">"Off"</constant>
<constant name="battFac1" units="ms/v">0.20</constant>
<constant name="cltType1">"GM"</constant>
<constant name="divider1">4</constant>
<constant name="egoCount1">16</constant>
<constant name="egoDelta1" units="%">1</constant>
<constant name="egoLimit1" units="%">15</constant>
<constant name="egoRPM1" units="RPM">1300</constant>
<constant name="egoSwitch1" units="v">0.510</constant>
<constant name="egoTemp1" units="°F">160</constant>
<constant name="egoType1">"Narrow band"</constant>
<constant name="engineType1">"Even fire"</constant>
<constant name="fastIdleT1" units="°F">145.0</constant>
<constant name="injOpen1" units="ms">1.0</constant>
<constant name="injPwmP1" units="%">75</constant>
<constant name="injPwmT1" units="ms">1.0</constant>
<constant name="injType1">"Port"</constant>
<constant name="mapBins1" rows="12" units="kPa">
20
30
40
50
60
75
90
100
110
120
130
170
</constant>
<constant name="mapSensor1">"1"</constant>
<constant name="mapType1">"250 kPa"</constant>
<constant name="matType1">"GM"</constant>
<constant name="nCylinders1">"4"</constant>
<constant name="nInjectors1">"4"</constant>
<constant name="reqFuel1" units="ms">6.4</constant>
<constant name="rpmBins1" rows="12" units="RPM">
1000
1600
2200
2800
3400
4000
4600
5200
5800
6400
7000
8000
</constant>
<constant name="rpmk1">3000</constant>
<constant name="twoStroke1">"Four-stroke"</constant>
<constant cols="12" name="veBins1" rows="12" units="%">
40 43 47 50 54 57 61 64 67 71 74 81
45 48 51 55 58 61 64 67 70 74 77 83
49 52 55 58 61 64 67 69 72 75 78 84
54 57 59 62 65 67 70 73 75 78 81 86
58 60 63 65 68 70 73 75 77 80 82 87
63 65 67 70 72 74 76 78 80 83 85 89
68 70 72 74 75 77 79 81 83 85 86 90
72 74 75 77 79 80 82 84 85 87 89 92
77 78 80 81 83 84 86 87 88 90 91 94
81 82 83 85 86 87 88 89 90 92 93 95
86 87 88 89 90 91 92 92 93 94 95 97
95 95 96 96 97 97 98 98 98 99 99 100
</constant>
</page>
<page number="1" size="200">
<constant name="TwoLambda">"None*^(DT)"</constant>
<constant name="algorithm2">"Speed Density"</constant>
<constant name="alternate2">"Simultaneous"</constant>
<constant name="baroCorr2">"Off"</constant>
<constant name="battFac2" units="ms/v">0.20</constant>
<constant name="cltType2">"GM"</constant>
<constant name="divider2">4</constant>
<constant name="egoCount2">0</constant>
<constant name="egoDelta2" units="%">1</constant>
<constant name="egoLimit2" units="%">10</constant>
<constant name="egoRPM2" units="RPM">1300</constant>
<constant name="egoSwitch2" units="v">0.510</constant>
<constant name="egoTemp2" units="°F">160</constant>
<constant name="egoType2">"Narrow band"</constant>
<constant name="engineType2">"Even fire"</constant>
<constant name="fastIdleT2" units="°F">-40.0</constant>
<constant name="injOpen2" units="ms">1.0</constant>
<constant name="injPwmP2" units="%">100</constant>
<constant name="injPwmT2" units="ms">25.5</constant>
<constant name="injType2">"Port"</constant>
<constant name="mapBins2" rows="12" units="kPa">
20
30
40
50
60
75
90
100
110
120
130
140
</constant>
<constant name="mapType2">"250 kPa"</constant>
<constant name="matType2">"GM"</constant>
<constant name="nCylinders2">"8"</constant>
<constant name="nInjectors2">"8"</constant>
<constant name="primePulse2" units="ms">1.3</constant>
<constant name="reqFuel2" units="ms">15.5</constant>
<constant name="rpmBins2" rows="12" units="RPM">
500
1000
1500
2000
2800
3600
4400
5200
5500
6000
6500
7000
</constant>
<constant name="rpmk2">1500</constant>
<constant name="taeColdM2" units="%">0</constant>
<constant name="twoStroke2">"Four-stroke"</constant>
<constant cols="12" name="veBins2" rows="12" units="%">
39 40 41 44 44 44 45 45 45 46 47 50
47 47 51 51 50 50 50 50 51 55 56 60
52 55 55 57 60 61 61 65 67 70 72 75
59 60 60 65 66 70 70 70 72 74 77 80
61 63 65 65 68 70 72 75 77 80 84 85
65 72 72 74 74 75 75 77 79 83 89 90
70 74 74 75 75 77 77 78 82 86 95 95
75 77 79 73 82 82 82 85 87 89 99 100
</constant>
</page>
<page number="2" size="200">
<constant name="CrankAng" units="Deg">10</constant>
<constant name="FixAng" units="Deg">-10</constant>
<constant name="IgHold">5</constant>
<constant name="IgInv">"No"</constant>
<constant name="TrigAng" units="Deg">50</constant>
<constant name="TrigCrank">"Trigger Return"</constant>
<constant name="Trig_plus">"0"</constant>
<constant name="Trim" units="Deg">0</constant>
<constant cols="12" name="advTable1" rows="12" units="deg">
9 9 10 15 22 32 36 36 36 36 36 36
9 9 10 15 21 30 32 32 32 32 32 32
10 10 13 15 20 28 30 30 30 30 30 30
10 10 13 15 19 27 28 28 28 28 28 28
10 10 13 15 19 23 26 26 26 26 26 26
10 10 11 14 17 22 24 24 24 24 24 24
10 10 10 13 16 21 23 23 23 23 23 23
10 10 9 11 15 20 22 22 22 22 22 22
10 10 8 10 14 19 19 19 19 19 19 19
</constant>
<constant name="mapBins3" rows="12" units="kPa">
20
30
40
50
60
75
90
100
110
120
130
170
</constant>
<constant name="rpmBins3" rows="12" units="RPM">
1000
1600
2200
2800
3400
4000
4600
5200
5800
6400
7000
8000
</constant>
</page>
<page number="3" size="200">
<constant name="AccDecEnrich">"TPSdot*^(DT)"</constant>
<constant name="AccelMapASE">"Normal"</constant>
<constant name="AfrTar">"Off*^(DT)"</constant>
<constant name="AfrTar2">"Off*^(DT)"</constant>
<constant name="AlphBaroCor">"No"</constant>
<constant name="BarroHi" units="KPa">205</constant>
<constant name="BarroLow" units="KPa">28</constant>
<constant name="BooTbl2Use">"Dont Switch*^"</constant>
<constant name="BoostDir">"Increase boost"</constant>
<constant name="BoostMaxKn" units="KPa">30</constant>
<constant name="CltAdv">"Off"</constant>
<constant name="DecEnrichment">"TPSdot*^(DT)"</constant>
<constant name="DecayAcPoint" units="mS">0.0</constant>
<constant name="DecayAccel">"None*^(DT)"</constant>
<constant name="DecelBoost">"Never*^"</constant>
<constant name="DecelKPa" units="KPa">255</constant>
<constant name="DtNos">"Bank1"</constant>
<constant name="EgoLim2" units="+-">5</constant>
<constant name="EgoLimKPa" units="KPa">255</constant>
<constant name="HCutLCSpark" units="Sparks">3</constant>
<constant name="HCutLCType">"Spark Cut Only"</constant>
<constant name="HCutSpark" units="Sparks">4</constant>
<constant name="HCutType">"Fuel & Spark"</constant>
<constant name="HardRevLim" units="rpm">8000</constant>
<constant name="IATBoost" units="°F">0.0</constant>
<constant name="IATBoostSt" units="°F">-40.0</constant>
<constant name="IStagedMode">"Off*^"</constant>
<constant name="IatAdvKpa" units="KPa">75</constant>
<constant name="IgAdvDeg" units="°F">27.0</constant>
<constant name="IgAdvTemp" units="°F">140.0</constant>
<constant name="IgRetDeg" units="°F">18.0</constant>
<constant name="IgRetTemp" units="°F">160.0</constant>
<constant name="InvOut1">"Normal"</constant>
<constant name="InvOut2">"Normal"</constant>
<constant name="KPA300BARO" units="%">100</constant>
<constant name="KPA300Corr" units="%">0</constant>
<constant name="KPA300Sens">"B+G Sensor*^"</constant>
<constant name="KPaDotBoost">"Never"</constant>
<constant name="KPaOn" units="KPa">80</constant>
<constant name="KPaTarg10" units="KPa">0</constant>
<constant name="KPaTarg100" units="KPa">0</constant>
<constant name="KPaTarg40" units="KPa">0</constant>
<constant name="KPaTarg60" units="KPa">0</constant>
<constant name="KnockAdv" units="Deg">1</constant>
<constant name="KnockBoost" units="KPa">0</constant>
<constant name="KnockKpa" units="KPa">255</constant>
<constant name="KnockMax" units="Deg">5</constant>
<constant name="KnockOn">"Off"</constant>
<constant name="KnockRet" units="Deg">2</constant>
<constant name="KnockRpm" units="RPM">5500</constant>
<constant name="KnockRpmL" units="RPM">1500</constant>
<constant name="KnockSb" units="Deg">1</constant>
<constant name="KnockTim" units="Sec">1</constant>
<constant name="KpaTPSTar">"Speed Density"</constant>
<constant name="LachDeg" units="Deg">5</constant>
<constant name="LachRpm" units="RPM">1900</constant>
<constant name="LachTps" units="Raw ADC">30</constant>
<constant name="LaunchLim" units="rpm">2200</constant>
<constant name="MaxIatAdv" units="Deg">5.3</constant>
<constant name="NosAngle" units="Deg">18</constant>
<constant name="NosClt" units="°F">120.0</constant>
<constant name="NosHiKpa" units="KPa">120</constant>
<constant name="NosLagSystem">"Off"</constant>
<constant name="NosLowKpa" units="KPa">80</constant>
<constant name="NosPWHi" units="mSec">0.3</constant>
<constant name="NosPWLo" units="mSec">1.2</constant>
<constant name="NosRpm" units="RPM">3000</constant>
<constant name="NosRpmMax" units="RPM">6000</constant>
<constant name="NosTps" units="Raw">200</constant>
<constant name="OLoopEgo">"TPS"</constant>
<constant name="Out1UpLim" units="raw byte or deg F +40">0</constant>
<constant name="Out2UpLim" units="raw byte or deg F +40">0</constant>
<constant name="Out3_Out1">"Source"</constant>
<constant name="OvrBCutType">"Spark Cut Only"</constant>
<constant name="OvrBKpa" units="KPa">175</constant>
<constant name="OvrRunC">"On"</constant>
<constant name="OvrRunClt" units="°F">60</constant>
<constant name="OvrRunKpa" units="KPa">20</constant>
<constant name="OvrRunRpm" units="RPM">1500</constant>
<constant name="OvrRunTimr" units="Sec">0</constant>
<constant name="OvrRunTps" units="Raw ADC">5</constant>
<constant name="RPM1S" units="3000RPM/Sec or 5%Slip">0.0</constant>
<constant name="RPM2S" units="4000RPM/Sec or 15%Slip">10.0</constant>
<constant name="RPM3S" units="6000RPM/Sec or 30%Slip">15.0</constant>
<constant name="RPM4S" units="10000RPM/Sec or 70%Slip ">20.0</constant>
<constant name="RPMThresh" units="RPM/Sec">2000</constant>
<constant name="ST2Delay" units="Sec">0.0</constant>
<constant name="STTable2On">"Spark Table1^"</constant>
<constant name="ScaleFac">255</constant>
<constant name="ShiftLower" units="rpm">5800</constant>
<constant name="ShiftUpper" units="rpm">6000</constant>
<constant name="SoftLimMax" units="s">5.0</constant>
<constant name="SoftLimRetard" units="deg">10</constant>
<constant name="SoftRevLim" units="rpm">1500</constant>
<constant name="SparkCutBNum" units="Sparks">3</constant>
<constant name="SparkCutBase" units="Sparks">5</constant>
<constant name="StartWIKPa" units="KPa">120</constant>
<constant name="StgDelta">3</constant>
<constant name="StgTrans">25</constant>
<constant name="TPSAFRPoint" units="Raw ADC">255</constant>
<constant name="TPSBooIAT" units="Raw ADC">0</constant>
<constant name="TPSRPMTarg">"TPS"</constant>
<constant name="TPSTar">"Always"</constant>
<constant name="TargetB1" units="Raw Value">0</constant>
<constant name="TargetB2" units="Raw Value">0</constant>
<constant name="TargetB3" units="Raw Value">0</constant>
<constant name="TargetB4" units="Raw Value">0</constant>
<constant name="TpsOn" units="Raw">192</constant>
<constant name="TractCySec">"RPM stable for 0.1S"</constant>
<constant name="TractCyc1" units="3000RPM/Sec or 5%Slip">3</constant>
<constant name="TractCyc2" units="4000RPM/Sec or 15%Slip">5</constant>
<constant name="TractCyc3" units="6000RPM/Sec or 30%Slip">8</constant>
<constant name="TractCyc4" units="10000RPM/Sec or 70%Slip">12</constant>
<constant name="TractMode">"RPM Based"</constant>
<constant name="TractNOS">"No"</constant>
<constant name="TractRet1" units="3000RPM/Sec or 5%Slip">0</constant>
<constant name="TractRet2" units="4000RPM/Sec or 15%Slip">20</constant>
<constant name="TractRet3" units="6000RPM/Sec or 30%Slip">20</constant>
<constant name="TractRet4" units="10000RPM/Sec or 70%Slip">30</constant>
<constant name="TractSC1" units="3000RPM/Sec or 5%Slip">0</constant>
<constant name="TractSC2" units="4000RPM/Sec or 15%Slip">0</constant>
<constant name="TractSC3" units="6000RPM/Sec or 30%Slip">1</constant>
<constant name="TractSC4" units="10000RPM/Sec or 70%Slip">2</constant>
<constant name="TractScale" units="%">49</constant>
<constant name="TractSlip" units="%">10</constant>
<constant name="TractSlipH" units="%">2</constant>
<constant name="TractVSSMax" units="V">5.00</constant>
<constant name="TractVSSMin" units="V">0.00</constant>
<constant name="TractionOn">"Off*^"</constant>
<constant name="UseVE3">"Dont switch*^(DT)"</constant>
<constant name="VE3Delay" units="Sec">0.0</constant>
<constant name="VLaunch">"Off"</constant>
<constant name="WaterIIat" units="°F">60.0</constant>
<constant name="WaterIRpm" units="RPM">3500</constant>
<constant name="WaterInj">"Off*"</constant>
<constant name="bcUpdateRate" units="ms">10</constant>
<constant name="bc_max_diff" units="kPa">255</constant>
<constant name="boostUse">"Output1*^"</constant>
<constant name="dGain" units="%">2.0</constant>
<constant name="dwellcont">"Dwell control"</constant>
<constant name="dwellcrank" units="ms">6.0</constant>
<constant name="dwellduty50">"50% duty cycle"</constant>
<constant name="dwellrun" units="ms">4.0</constant>
<constant name="edis">"Off*^"</constant>
<constant name="edismulti">"Off*^"</constant>
<constant name="edismultirpm" units="rpm">1100</constant>
<constant name="efanofftemp" units="°F">145.0</constant>
<constant name="efanontemp" units="°F">194.0</constant>
<constant name="egoIgnCount">"Ign Pulses*^"</constant>
<constant name="fastIdleRPM" units="RPM">1100</constant>
<constant name="fastIdleTemp" units="°F">65</constant>
<constant name="fidleUse">"Idle control*"</constant>
<constant name="freqDiv">"13.0 Hz"</constant>
<constant name="hei7">"Off*^"</constant>
<constant name="hybridAN">"Off*^"</constant>
<constant name="idleThresh" units="%">2</constant>
<constant name="idle_dc_lo" units="dc%">50</constant>
<constant name="idledashdc" units="dc%">45</constant>
<constant name="idlekickdc" units="dc%">55</constant>
<constant name="idlekickrpm" units="RPM">700</constant>
<constant name="idlemindc" units="dc%">27</constant>
<constant name="idleperiod" units="ticks">25</constant>
<constant name="ignmode">1.00000000000000000000000000000000</constant>
<constant name="inj1g">"off"</constant>
<constant name="inj2cr">"On*^"</constant>
<constant name="inj2g">"on*^"</constant>
<constant name="inj2t">"1*^"</constant>
<constant name="launchUse">"Off*^"</constant>
<constant name="led17Use">"Spark output"</constant>
<constant name="led18Use">"IRQ trigger"</constant>
<constant name="led18_2Use">"0"</constant>
<constant name="led19Use">"Acceleration*^"</constant>
<constant name="maeBins4" rows="4" units="ms">
2.0
5.0
10.5
15.0
</constant>
<constant name="maeRates4" rows="4" units="ms">
50
100
150
250
</constant>
<constant name="mapProportion4">"TPSdot*^(DT)"</constant>
<constant name="mapThresh4" units="kPa/s">300</constant>
<constant name="mindischg" units="ms">0.5</constant>
<constant name="msnsCyl">"MSnS^"</constant>
<constant name="neonCrank">"Off*^"</constant>
<constant name="nitrousUse">"Off*"</constant>
<constant name="numteeth">12</constant>
<constant name="onetwo">"-1"</constant>
<constant name="out1Hysis" units="raw byte or deg F">0</constant>
<constant name="out1lim" units="raw byte or deg F +40">0</constant>
<constant name="out1src">"Off*"</constant>
<constant name="out2Hysis" units="raw byte or deg F">0</constant>
<constant name="out2lim" units="raw byte or deg F +40">0</constant>
<constant name="out2src">"Off*"</constant>
<constant name="out3Timer" units="Sec">0.0</constant>
<constant name="out3lim" units="raw byte or deg F +40">0</constant>
<constant name="out3sparkd">"Output3"</constant>
<constant name="out3src">"Off*"</constant>
<constant name="out4FAN">"Source"</constant>
<constant name="out4lim" units="raw byte or deg F +40">0</constant>
<constant name="out4src">"Off*"</constant>
<constant name="pGain" units="%">25.1</constant>
<constant name="pwmIdle">"B&G On-Off*^"</constant>
<constant name="pwmidlewhen">"INVALID"</constant>
<constant name="shiftUse">"Off*^"</constant>
<constant name="slowIdleRPM" units="RPM">650</constant>
<constant name="slowIdleTemp" units="°F">194</constant>
<constant name="taeBins4" rows="4" units="ms">
2.0
5.0
10.5
15.0
</constant>
<constant name="taeColdA4" units="ms">3.0</constant>
<constant name="taeColdM4" units="%">100</constant>
<constant name="taeIgnCount">"Sec*^"</constant>
<constant name="taeRates4" rows="4" units="ms">
1.0
3.9
7.8
15.1
</constant>
<constant name="taeTime4" units="ms">0.2</constant>
<constant name="tdePct4" units="%">100</constant>
<constant name="tfi">"Off*^"</constant>
<constant name="toy_dli">"Normal*"</constant>
<constant name="tpsThresh4" units="v/s">0.586</constant>
<constant name="trig1">0</constant>
<constant name="trig1ret">0</constant>
<constant name="trig2">0</constant>
<constant name="trig2ret">0</constant>
<constant name="trig3">0</constant>
<constant name="trig3ret">0</constant>
<constant name="trig4">0</constant>
<constant name="trig4ret">0</constant>
<constant name="wd_2trig">"Missing teeth"</constant>
<constant name="wheelon">"Off*^"</constant>
<constant name="whlsim">"off"</constant>
<constant name="whlsimcnt">4</constant>
<constant name="x2use">"Fan control"</constant>
</page>
<page number="4" size="200">
<constant name="AlwaysPrime">"Prime Pulse>0*^"</constant>
<constant name="CrankPWT1" units="mS">18.1</constant>
<constant name="CrankPWT10" units="mS">3.1</constant>
<constant name="CrankPWT2" units="mS">12.1</constant>
<constant name="CrankPWT3" units="mS">8.1</constant>
<constant name="CrankPWT4" units="mS">6.1</constant>
<constant name="CrankPWT5" units="mS">5.6</constant>
<constant name="CrankPWT6" units="mS">5.1</constant>
<constant name="CrankPWT7" units="mS">4.6</constant>
<constant name="CrankPWT8" units="mS">4.1</constant>
<constant name="CrankPWT9" units="mS">3.6</constant>
<constant name="CrankRPM" units="rpm">300</constant>
<constant name="PrimeLate">"Power Up*^"</constant>
<constant name="PrimePulse" units="mS">0.4</constant>
<constant name="PrimeTBox">"Priming Table"</constant>
<constant cols="12" name="advTable2" rows="12" units="deg">
</constant>
<constant name="crankpwip">"CLT only*^"</constant>
<constant name="mapBins4" rows="12" units="kPa">
30
40
50
60
70
80
90
100
110
120
130
140
</constant>
<constant name="rpmBins4" rows="12" units="RPM">
500
700
1300
2000
3000
4000
5000
6000
6100
6200
6300
6400
</constant>
<constant name="tpsflood" units="raw">178</constant>
<constant name="wueBins5" rows="10" units="%">
180
180
160
150
135
125
114
110
108
100
</constant>
</page>
<page number="5" size="200">
<constant name="ASEFixDe">"Decay *^"</constant>
<constant name="ASEFixTemp" units="°F">45.0</constant>
<constant name="ASEFixTim">5</constant>
<constant name="ASETable1" units="%">30</constant>
<constant name="ASETable10" units="%">5</constant>
<constant name="ASETable2" units="%">20</constant>
<constant name="ASETable3" units="%">15</constant>
<constant name="ASETable4" units="%">12</constant>
<constant name="ASETable5" units="%">10</constant>
<constant name="ASETable6" units="%">9</constant>
<constant name="ASETable7" units="%">8</constant>
<constant name="ASETable8" units="%">7</constant>
<constant name="ASETable9" units="%">6</constant>
<constant name="ASETime">250</constant>
<constant name="VEFixASE">"Normal MAP *^"</constant>
<constant name="VEFixValue" units="kpa">67</constant>
<constant name="aseIgnCount">"Cycles*^"</constant>
<constant name="mapBins5" rows="12" units="kPa">
20
30
40
50
60
75
90
100
110
120
130
150
</constant>
<constant name="rpmBins5" rows="12" units="RPM">
500
1000
1500
2000
2800
3600
4400
5200
5500
6000
6200
6500
</constant>
<constant cols="12" name="veBins3" rows="12" units="%">
</constant>
</page>
<page number="6" size="200">
<constant cols="8" name="afrBins1" rows="8" units="Volts">
2.88 2.88 2.88 2.88 2.88 2.88 2.88 2.88
2.55 2.55 2.55 2.55 2.55 2.55 2.55 2.55
2.45 2.45 2.45 2.45 2.45 2.45 2.45 2.45
2.35 2.35 2.35 2.35 2.35 2.35 2.35 2.35
</constant>
<constant cols="8" name="afrBins2" rows="8" units="Volts">
</constant>
<constant name="mapBins6" rows="8" units="kPa">
15
30
50
60
90
100
110
150
</constant>
<constant name="mapBins7" rows="8" units="kPa">
15
30
50
60
90
100
110
150
</constant>
<constant name="rpmBins6" rows="8" units="RPM">
500
1000
1500
2000
2800
3600
5000
6000
</constant>
<constant name="rpmBins7" rows="8" units="RPM">
500
1000
1500
2000
2800
3600
5000
6000
</constant>
</page>
<page number="7" size="200">
<constant cols="6" name="bcBins1" rows="6" units="kpa">
100 100 100 100 100 100
100 120 120 120 120 120
</constant>
<constant cols="6" name="bcBins2" rows="6" units="duty">
20 20 20 20 20 20
20 20 20 20 20 20
20 20 20 20 20 20
20 20 20 20 20 20
20 20 20 20 20 20
20 20 20 20 20 20
</constant>
<constant cols="6" name="bcBins3" rows="6" units="kpa">
</constant>
<constant name="bcrpmBins1" rows="6" units="RPM">
1000
2000
3000
4000
5000
7000
</constant>
<constant name="bcrpmBins2" rows="6" units="RPM">
1000
2000
3000
4000
5000
7000
</constant>
<constant name="bcrpmBins3" rows="6" units="RPM">
1000
2000
3000
4000
5000
7000
</constant>
<constant name="bctpsBins1" rows="6" units="tps%">
20
30
40
50
70
90
</constant>
<constant name="bctpsBins2" rows="6" units="tps%">
20
30
40
50
70
90
</constant>
<constant name="bctpsBins3" rows="6" units="tps%">
20
30
40
50
70
90
</constant>
<constant name="fixedsplit" units="deg">-10</constant>
<constant name="rotary2">"Off"</constant>
<constant cols="6" name="splitTable" rows="6" units="deg">
-0 21 21 21 21 21
-0 16 16 16 16 16
-0 10 10 10 10 10
-0 5 5 5 5 5
-0 -0 -0 -0 -0 -0
-1 -1 -1 -1 -1 -1
</constant>
<constant name="splitkpaBins" rows="6" units="kpa">
40
50
60
80
105
106
</constant>
<constant name="splitrpmBins" rows="6" units="RPM">
600
800
3000
4000
5000
7000
</constant>
</page>
</msq>
20
30
40
50
60
75
90
100
110
120
130
170
</constant>
1000
1600
2200
2800
3400
4000
4600
5200
5800
6400
7000
8000
</constant>
</constant>
</page>
20
30
40
50
60
75
90
100
110
120
130
140
</constant>
500
1000
1500
2000
2800
3600
4400
5200
5500
6000
6500
7000
</constant>
</constant>
</page>
</constant>
20
30
40
50
60
75
90
100
110
120
130
170
</constant>
1000
1600
2200
2800
3400
4000
4600
5200
5800
6400
7000
8000
</constant>
</page>
2.0
5.0
10.5
15.0
</constant>
50
100
150
250
</constant>
2.0
5.0
10.5
15.0
</constant>
1.0
3.9
7.8
15.1
</constant>
</page>
</constant>
30
40
50
60
70
80
90
100
110
120
130
140
</constant>
500
700
1300
2000
3000
4000
5000
6000
6100
6200
6300
6400
</constant>
180
180
160
150
135
125
114
110
108
100
</constant>
</page>
20
30
40
50
60
75
90
100
110
120
130
150
</constant>
500
1000
1500
2000
2800
3600
4400
5200
5500
6000
6200
6500
</constant>
</constant>
</page>
</constant>
</constant>
15
30
50
60
90
100
110
150
</constant>
15
30
50
60
90
100
110
150
</constant>
500
1000
1500
2000
2800
3600
5000
6000
</constant>
500
1000
1500
2000
2800
3600
5000
6000
</constant>
</page>
</constant>
20 20 20 20 20 20
20 20 20 20 20 20
20 20 20 20 20 20
20 20 20 20 20 20
20 20 20 20 20 20
20 20 20 20 20 20
</constant>
</constant>
1000
2000
3000
4000
5000
7000
</constant>
1000
2000
3000
4000
5000
7000
</constant>
1000
2000
3000
4000
5000
7000
</constant>
20
30
40
50
70
90
</constant>
20
30
40
50
70
90
</constant>
20
30
40
50
70
90
</constant>
-0 21 21 21 21 21
-0 16 16 16 16 16
-0 10 10 10 10 10
-0 5 5 5 5 5
-0 -0 -0 -0 -0 -0
-1 -1 -1 -1 -1 -1
</constant>
40
50
60
80
105
106
</constant>
600
800
3000
4000
5000
7000
</constant>
</page>
</msq>
That MSQ is for version 024s and not 029q2
Loading into Megatune with msns-extra.ini.024s activated it looked ok.
Do you have the right ini file Activated? Do you get any error messages when starting Megatune?
What firmware do you have loaded?
An 024s MSQ ought to load into 029q2 ok, but you would need to review your settings and in particular re-enter your warmup/afterstart values.
Do you get any Megatune errors?
If not then I think you have have a fault on the board - check around the transistor that drives the LED for any short circuits.
I have 2 MS and both have the same problem. I am not a great tuner. I received an error on my Megatune that said "The megatune send a 029b2 and received a 029q2" or something like that.
In my megasquirt board;
For input:
I removed the jumper on XG1 and XG2 and put the Hall Sensor on X11 with a jumper from X11 to XG1 and input 12V on Pin24 with a 430 resistor.
For output:
I'm using the VB921 with the RHS of R25.
For input:
For output:
Please do not ignore this error. It is critical and will usually mean that data is being sent to the wrong place in memory. You MUST use the correct .ini file to avoid this error message and likely data corruption.hzdistributor wrote:I have 2 MS and both have the same problem. I am not a great tuner. I received an error on my Megatune that said "The megatune send a 029b2 and received a 029q2" or something like that.
Why are you using the VB921 when you have an MSD ?
Skip the VB921 and connect the (-) of LED17 over to X11 then connect the MSD white wire to pin 25 of the DB37
It comes in the zipfile. Read the README (and the setup instructionshzdistributor wrote:I tried to find the correct ini file for 029q2 but I couldn't find it.
http://megasquirt.sourceforge.net/extra/setup.html) and run COPYINI.
A lot of thanks....
Hi Cortina:
Thanks for all your help. I found the error. The problem was the following:
The schematics of the Hall Sensor wiring showed a resistor of 10? in the 12v+ wire and I used a 10K instead of a 10ohm, when I used the 10ohm work fine.
Connected to the external ignition worked fine because the ignition was not grounded.
Now I have work to do tuning.
Thanks.
Thanks.
