Help with sensor wiring
hi all, im wiring my ms to my car and have a few questions about conncting up. im using MS3 with V1 and MSnSe code, i have a vauxhall 20 16v engine with dis pack
now i have connected up the injectors fine, and the spark to my spark control module (0 227 100 200) ecu dwell control.
now my car has a crank sensor 60/2 but also has a cam sensor, now how do i connect them both up or do i just connect the crank sensor and not use the cam sensor, also on my ignition control module i have 4 wires 2 to control spark, what would the other 2 be for any help woul be great cos i want her started today if i can
Think they are the same type of engine aint they, might be wrong tho.
now i connected it up and no no no, nothing
Fuel Pump Primes and can hear Injectors go squirt, but i aint getting a RPM signal, now i am assuming its a Hall sensor, so have set the jumpers on the V3 pcb. but i still aint getting out its driving me bloomin mad. i just want it to work so i can start the turbo conversion
how u got the crank sensor wired up ????
if u have cut the plug on the crank sensor u will see 2 wirs and the outer ground ( off the top of my head i carnt remeber what colours ) but this is how ive got mine wired i took the main signal wire from the vr ciruit and put that to the crank sensor and then i got the ground and the outer ground on the crank sens and put them together and joined them to the ground on the vr ground
vr + to main wire in crank sensor
vr - to both ground and outer ground on crank sensor
worked for me
i spent weeks trying to get mine to work so i tryed it that way and it worked
worked for me
2.0 8v turbo 10.7 standing 1/4@136mph on m/s fastest mk2 astra 8vt in europe !!!
2.0 turbo tigra 10.1 standing 1/4 @ 145 mph with problems havent turned the boost up yet
still no joy with this, tried all sorts. i have deffo got everything wire uo correct apart from the crank sensor, im just not sure i was 99% sure it was a hall sensor so i set the pcb up for a hall circuit, but i still get no SIGNAL is there a way to test the sensor on a Multimeter to see if it works
ok dokey i have set up the VR circuit now and tunred both pots fully anti clockwise, but i just cant get her to fire. if the lambda sensor was a bit sick would this stop it!!! or if the map sensor of not working would this stop it??????
i have the spark paired as 1+2 3+4 and injectors as 1+2 3+4 VR circuit is working RPM signal, fuel pump is working. i used EasyTherm to set the Temp sensors
