If your missing teeth reside between your trigger and trigger return, do you need to go to Time Based cranking, or will Trigger return still work?
Example:
60-2 wheel
Trigger A : 14
Trig Return A: 23
Trigger B : 29
Trig Return B: 38
Trigger C : 44
Trig Return C: 53
Trigger D : 59
Trig Return D: 8
Gap resides between Trigger D and Trigger Return D
Missing tooth between trigger and return
