MSnS-E 029q2 MSv3 Megatune 2.25 V6 fuel only innovative wideband
Hi guys I installed a wideband a bit ago and I would like to use the AFR table but I just have a few questions.
One the AFR table is 8x8 do I just make the kpa and rpm as close to my VE table and then punch in what AFR I want to run at what RPM KPA or do I make it match exactly to my VE table just skipping a few rpm KPA in between.
Two with the AFR table on it ignors the switch voltage in the ego page and gets all the info from the Afr table.
Thanks for anyones help
Thanks 71jeep
AFR table question
Thankyou Kieth.....
I had read the write up on the MSNS-E site but was still a bit confused because the AFR table is 8x8 and my VE is 12x12 I was not sure if I made it look as close as possible to my VE table or just make a table up and go with it or if there was some tick to it .
Is there more on the AFR table in the megamanual that I can read up on?
Thankyou 71jeep
Thankyou 71jeep
