Has anyone had any luck getting the OEM crankshaft position sensor working with the OEM trigger wheel?
Here's a picture of what the wheel looks like:
http://www.flyinmiata.com/index.php?dep ... r=07-91000
After having a bit of a read it looks as though this may be what is required, but I'm not so sure:
http://megasquirt.sourceforge.net/extra ... wheel.html
If you look closely the triggers aren't evenly spaced, looks to be a bit of a beast!
Cheers,
Tim
NB MX-5/Miata crank trigger wheel
You should be able to trigger the MS from a 1.6 CAS and leave the stock ECU on the stock trigger.
I couldn't tell from the picture on the FM site with any certainty that the teeth are or are not evenly spaced. The teeth in the picture are no more than a pixle or two wide. You'd need a picture of the wheel straight on or some other reference material to know if they are uneven.
