OK,
MSextra version 29i
This was running on previuos Rover 4.6, however, i have changed the engine and run into a small problem:
If i load my base msq onto my laptop, then communicate with the MS i can start the car without any problems.
If i then switch it off and then try to restart it will not start at all!!!
I am sure this is me - but i can not see the wood for the tree's
Any ideas as to what i am doing wrong??
Cheers
Nev
Car Starts and Runs but when i switch off it will not start
check acc enrichments i had that i could get it to start but then after that it would not start didnt matter how hard i tryed turned out the acc enrichments werent on
2.0 8v turbo 10.7 standing 1/4@136mph on m/s fastest mk2 astra 8vt in europe !!!
2.0 turbo tigra 10.1 standing 1/4 @ 145 mph with problems havent turned the boost up yet
Where did your "base map" come from? I'm wondering if it contains some errors or invalid settings?
Do you get any errors when starting Megatune ?
No errors are reported but i have had success with using an old map i had used with 4.6 - its not very close and requires alot of fiddling but at least it appears to stay in the MS
I have attached the working and non working msq's as a comparison the top one is one that will not 'stay in' the bottom one appears to load in fine (although very very roughly tuned so far).
Nev
Nev
