Car Starts and Runs but when i switch off it will not start
nevtiger
Post by nevtiger »
OK,
MSextra version 29i
This was running on previuos Rover 4.6, however, i have changed the engine and run into a small problem:
If i load my base msq onto my laptop, then communicate with the MS i can start the car without any problems.
If i then switch it off and then try to restart it will not start at all!!!
I am sure this is me - but i can not see the wood for the tree's
Any ideas as to what i am doing wrong??
Cheers
Nev
screamer69
Post by screamer69 »
check acc enrichments i had that i could get it to start but then after that it would not start didnt matter how hard i tryed turned out the acc enrichments werent on
2.0 8v turbo 10.7 standing 1/4@136mph on m/s fastest mk2 astra 8vt in europe !!!
2.0 turbo tigra 10.1 standing 1/4 @ 145 mph with problems :( havent turned the boost up yet
shaodome
Post by shaodome »
You have a conflicting config error most likely. Is your fuel pump going on/off?
nevtiger
Post by nevtiger »
Well, the pump seems to becoming on and then going off again upon power up, but if i load up my new map when the MS is powered up then pump stays on.
Post by jsmcortina »
Where did your "base map" come from? I'm wondering if it contains some errors or invalid settings?
Do you get any errors when starting Megatune ?
nevtiger
Post by nevtiger »
No errors are reported but i have had success with using an old map i had used with 4.6 - its not very close and requires alot of fiddling but at least it appears to stay in the MS
I have attached the working and non working msq's as a comparison the top one is one that will not 'stay in' the bottom one appears to load in fine (although very very roughly tuned so far).
Nev
