One last problem. (datalogs, pictures, HELP!)
AlHounos
Post by AlHounos »
V3 29q2
wheel decoder, 24s mode
running resistor plugs
running low-z injectors, PWM at ~38%
I am having what seem to be completely random tach spikes. The car may run great for several miles, only to begin stuttering and bucking at random.
I am using crimped connections to the OEM wiring harness I have checked them all for good connection. Using the OEM ECU ground for one ground and the other is grounded to a floorboard bolt shared with LC1 grounds.
I think I can rule out bad connections. Grounds should be fine.
Could there be bad capacitors on my board? How should I check? Is the injector PWM causing interference?
Should I post a bunch of pictures of my wiring and board mods?
As I said, the car does run great for some periods, but these problems are bad enough to make the car unusable.
THANKS!
Revving in neutral, car cold:
Driving:
AlHounos
Post by AlHounos »
Anyone? I tried powering the CAS off the MS power and ground, but no change.
AlHounos
Post by AlHounos »
Just for future reference, the PWM for the low-z injectors was causing the problem.
cossie_storm
Post by cossie_storm »
what did you put it to?
Ford sierra Is turbo 88
Turbo t-3 Audi s2 dyser ca 345cc
Megatune 2.25
Msns-s 0.29 Q
ms v 2.2
AlHounos
Post by AlHounos »
I installed my old high impedance injectors and set the PWM accordingly. 100% and 25.4ms.
