do i have it right? 4agze-dual wheel.
ok, just wanted to make sure i got it right. im running a 4agze with toyota vast system. plug n play harness set up like jamesL. so, from what i can gather, since i have two VR wheels i can run my main 24tooth NE signal through the conditioner on the V3.0 board then to the IRQ input, then i can splice the G1 and G2 signals together and then use a 4pin HEI to condition the signal, put a 1K risistor inline and then wire that to pin 11 using the JS8 jumper. and my G- goes to ground. does this all sound right? thanks for the help.
What the Douce?
