I booted my proto car MS I up today hooked to my PC and it gave me a error saying that it found 24 on my MS and it expected 29.
Do I need to change this or should I leave it alone??
Thanks JS
CAN THE Code be different?
If MegaTune is using the wrong .ini file and talking to the MS you`ll definitely get errors and won`t be able to set all the options correctly.
If you have msns-extra024 on the MegaSquirt you won`t need to use the boot jumper, just use the DownloadFirmware icon and follow the prompts.
Squirted VW GTI 16vG60 mk2
