Found a Problem with code 029q2 with MT 2.25
qadir03
Post by qadir03 »
I've been having some ignition advance problem and spark cutting out with the hall effect distrib on an Audi Urq Quattro. I have described the problem below at the following thread:
http://www.msefi.com/viewtopic.php?t=19726
I was then given the idea of using an older code and see if it still does it. So I loaded 024f2 with MT225b442, and sure enough the car started right up and the problem gone!! I tried to look online for a little newer code that has the autotune and follow feature, but I couldn't find any. The 024f2 has some issues when doing a table transform so I want something that is a more stable for tuning sakes.
