MSnS-Extra, V2.2 board, Wheel decoder
I'm a bit confused...
To use LED17 as spark-output:
1Kohm resistor from RHS of R23 to neg.-side of D17.
Wire from neg.side og D17 to X11
From DB37 pin 25 to pin 6 of Ign.module
To use Honeywell GT101 hall sensor:
1Kohm resistor between Pin24 (hole right of R29) to Pin28 (free hole near X12 and x13)
Sensor output to Pin 25 (but i use pin 25 to ign.module?!)
Cut jumper from XG1 to XG2
Wire from XG1 to X11
Feed sensor using a 10ohm resistor
Change Q5 to a TIP121 darlington
Change R16 to a 510ohm resistor
Pin 30 to Idle-valve
Feed idle-valve with power from Fuel-pump relay
Wiring LED17 as Spark output and use FIDLE as PWM-idle
Re: Wiring LED17 as Spark output and use FIDLE as PWM-idle
Use the "alternative to schematic 2" where the Hall sensor come in on pin 24, see http://megasquirt.sourceforge.net/extra/setup-msns.htmlVezzel 309 GTI16 wrote: To use Honeywell GT101 hall sensor:
I'm using schematic 2 - and that connects hall-output to pin 25.jsmcortina wrote:Use the "alternative to schematic 2" where the Hall sensor come in on pin 24, see http://megasquirt.sourceforge.net/extra/setup-msns.htmlVezzel 309 GTI16 wrote: To use Honeywell GT101 hall sensor:
And also use pin 24 where it got connected to pin28 using a resistor...
Does this look right?
Wire from neg.side og D17 to X12
From DB37 pin 27 to pin 6 of Ign.module
To use org 2-pin Bosch PWM idle-valve:
Change R16 to a 510ohm resistor No - I leave R16 as original
