MS1 Pwm Idle does not work.
Challengr,
I have never touched the frequency since I first started using the valve. 200 did not work for me it only made the cycling go faster. 50 really seemed to slow down the response of the valve and give it more time to stabilize.
Now I am using 100 RPM for fast response and 20 RPM for slow with a fast time of 10 and a slow time of 30 with a dead band of 30.
So far it is very stable. It will be cool again tomorrow morning and I will see if it continues to work well.
Thanks!!!!
Thanks!!!!
Ok so what the secret?? I keep winding up with large numbers for fast and slow recovery to I get a stable idle BUT then when I turn on the lights on or the fan kicks in PWMidle can't respond fast enough.
Do I need to stretch the RPM range of fast and slow recovery so it has less slope? I'm looking for anything here. My car seems extremely sensitive to AFR and timing at idle, which maes PWM tuning difficult.
superchargingmachine,
Maybe now that you have a stable idle, you should try setting frequency to 200 again. When you do, remember to increase your dashpot and cranking PWM values proportionately. This might give you the fast response you need for sudden loads like fans and lights.
With my settings, idle recovers instantly when I go from neutral to drive (automatic trans).
Jeff
Jeff
I got stuck in the dashpot loop again today. My experience is that I get a stable idle but it doesn't stay stable.
I adusted the TPS setpoint in the dashpot settings and that seemed to get me out of the dashpot loop.
If I can keep from getting stuck in the dashport loop for a while then I can concentrate on a nice stable idle. I will try increasing the frequency again if I can get away from these dahpot problems
Ok - How does Dashpot get it's starting TPS ADC? It seems it grabs a value during cranking. So if you touch the gas at all on startup you can get an erroneous TPS ADC number sending you into dashpot hell. It seems like now that I have increased my startup time and cranking dc for the valve that if I don't touch the gas on startup all is well.
I will update this tomorrow.
Challengr,
No matter what setting I use I can't get 200 freq to work. I can it seems get 50 or 100 to work.
Challengr,
I FOUND what is the biggest problem with my setting. IdleDC 90 presents about 1700rpm, 89 1200 and 88 closed.. I tried frequency 90 and 110 those doesn't work any better. 90 rises engine speed up to 3200 at 89dc. 110 Does opposite effect. What can I do?? All my present settings are found earlier in this post.
Volvo 244 gle, b19e msns. R.I.P.
Vauxhall Viva, Msns. "Finally working"
Volvo 945 Turbo -97, Ms II. "There can't be more resistant install than this"
I would look at your warmup enrichment values first before looking at PWMidle settings.
I did notice a problem in your settings in your previous post. Your closed dc is greater than either your minimum or your cranking. I don't think this will work. Closed should be your smallest value, minimum should be somewhere below where the car idles, cranking should be just above the max engine speed where PWMidle is active.
I hoped that I could found an answer to same question from here...superchargingmachine wrote:How can such a small range have such a huge effect on RPM?
What valve are you using and on what size engine?
My valve is a 2 wire Ford from a 3.0V6 and I am using it on a 1.6L. On my car 900RPM = 10-13dc 2000RPM = 28-30dc.
Valve (bosch number 0280140516) is from 2.0 litre Alfa Romeo. It contains 19mm hose connectors. Valve is allso used 3.0litre v6 alfa.
It is normal rotating type. With no electric, valve is slightly open. Small pwm it is closed and so on.
Masi_K wrote:I hoped that I could found an answer to same question from here...superchargingmachine wrote:How can such a small range have such a huge effect on RPM?
It is normal rotating type. With zero pwm, valve is slightly open. Small pwm it is closed and so on.
Fred,
Please set your closeDC to 25 and your minDC to 35 and see if that helps.
The valve you are using is closed at 25% PWM duty Cycle. Idle regulation should happen at about 40% and cranking should be 50-60%, at least that is how it works on mine. The closeDC is the DC at which the valve passes no air (or as close to no air as possible) MinDC is a DC value which is slightly below the value at which the idle is regulated at the warm idle set point. In a stock installation on a Saab, this particular valve regulates at about 40% and is open significantly greater as IAT increases.
KeithG
KeithG
fred, please screen capture your 2 pages of pwmidle settings. If not, please post your current msq. Maybe we can help.
KeithG
Posted by email.
KeithG
Posted by email.
