Do I have to run the 25uf radio supression if no radio?
I don't have a radio. Do I still have to run it?
'65 VW Bus with a Subaru EJ20 Turbo conversion , Air to water I/C , LS coils , 14Point7 Spartan 2 & Solid Air Fuel Ratio 52mm gauge.
MS2 Extra V3.0 board
Its not the 'radio' that causes interference, its the ignition coils that generate interference on the 12v line.
The cap smooths the interference so those with radio's dont hear the interference, but also it stops that interference affecting other sensitive electronics - the MS in this case
In laymans terms - it can help limit problems later on
Geared Ghia - UK Ford Escort 1800.
