4AGE motor loses RPM signal at ~2200rpm (HEI4 issue?)
Post by jsmcortina »
elturbonitroso wrote:ok i did alredy the input mods now do i have to change my code type set up to hei 7 pin or everything stay the way its.
Leave it set to Dizzy(MSnS)
All HEI7 really adds is the bypass output.
elturbonitroso
Post by elturbonitroso »
ok im going to try to put my ms in the car today and see what happen.
elturbonitroso
:D its a succes story now its time tofine tune the car thanks james and specialy thanks jeff the car seen to like the 7 pin.
Fastest95PGT
Post by Fastest95PGT »
Great to hear about your success Angel!
Now it doesn't seem so strange when I got there and said "I didn't know you could use a 4 pin HEI to VR condition". :lol:
1995 Ford Probe GT ~ Megasquirted & Boosted
275whp/242wtq @ 5.5psi ---- 317whp/287wtq @ 8.5psi
^^^ (thanks to MSnS-E and dyno tuning by me!)
2003 GSX1300R (Hayabusa)
Phew!
Glad you got that sorted.
There were/are people using the 4pin with success but others have had the same issues as you.
elturbonitroso
i drove the car and everything see ok just need more tunning but is a complete succes. uppi :lol: :lol:
Fastest95PGT
What would any of us do without you James? Would we actually have to use the search feature?? ;)
Thanks for helping Angel out. Sounds like it's running pretty well on the base MS default tune and we'll get it tuned up to some nice HP next time I go down there. 8)
Gavin Lodewick
Post by Gavin Lodewick »
Hi jsmcortina
I have just read this post on the 7 pin VR triger.
My Q is if i run my wastspark on my V2.2 board, will this setup work
with 7 pin VR setup as explained in this post.
Regardes
Gavin
Gavin Lodewick
Hi James
Running 2 VB921 as wastspark on the V2.2 board,this was not stated in
the last post .
Gavin
I do not believe that anyone has tried to run the HEI7 with a multi-toothed wheel. They were not designed for that signal so it might not work. I use the LM1815 circuit on my car.
Gavin Lodewick
Thanks James
All I want it for, is a VR picup signel for the VR +& - senser.
I will set one up on my test center, and see how it responds over the
weekend or so.
Many Thanks
Gavin
Fastest95PGT
I think what James is referring to is the maximum tooth count a HEI can handle in a certain amount of time. The thread is talking about a 2 tooth trigger per revolution which is now being conditioned by a 7 pin HEI. However, to do a wasted spark setup, you'd need at least double the teeth (minus one or plus a cam angle sensor) to do it so that's 4 teeth per revolution of the motor and I'm not sure if the HEI can handle that at lets say 7k rpm.
James, am I correctly on this? Any chance you could find a link to a thread which discusses this? I've tried to search before to greaten my understanding on the subject of maxing out a HEI's resolution but haven't been able to find any which specifically discussed it (probably burried in a thread somewhere?).
cossie_storm
Post by cossie_storm »
Fastest95PGT:
I have the same problem. rpm drops, and suddenly get back on track again. But i'm not using vr sensor, but Tfi.
any ideas?
Ford sierra Is turbo 88
Turbo t-3 Audi s2 dyser ca 345cc
Megatune 2.25
Msns-s 0.29 Q
ms v 2.2
Fastest95PGT
I'd suggest you start a new thread in this forum to discuss it. List your vehicle, motor, ignition trigger type, and any component between the ignition trigger and the MS.
From your sig it doesn't appear you have a 4AGE motor so it doesn't really apply to this thread.
