im thinking about putting a shift light in now so i just want to double check a few things
according to diagram bottom one of the three
i use js7 (pin10 ) circuit on the m/s and alter the 220r to suit the led used ??
so if im right as im not that briilent at electronic ( noooob but willing to learn )
if i was to use a 12v led then i dont use 220r ??
but looking at the diagram it works by triggering the ground is this right
instead of putting power to the led its just grounding the led once its got to the right setting
cheers
and sorry for sounding like a nob ( we all have to learn some where )
shift light
shift light
2.0 8v turbo 10.7 standing 1/4@136mph on m/s fastest mk2 astra 8vt in europe !!!
2.0 turbo tigra 10.1 standing 1/4 @ 145 mph with problems havent turned the boost up yet
Thats right.Most electronic switching switches the component to ground to complete the circuit.A 12v led will have the required resistance built in.Most std leds have a rated current and the resistor must be selected to reduce circuit current to this level.
Ohms law current (I) in Amps = Volts / resistance in Ohms.
so I=V/R or V=IR or R=V/I for whatever you want to find.
If anyone else is looking for a shift light, check these out.
http://www.ecliptech.com.au/
Quality product, and the guy who makes them is a champion[/url]
