Once you do the edis mods to the megasquirt board will the stimulator still work with it or no?
The reason I ask is I just did all the mods to my board and when I hook up the stimulator the fuel pump light blinks and then goes right out. So I am worried that I may have damaged the board. Is this so or...is it just how it works?
If so is there a mod for the stimulator to get it to work again?
Also I when I did the mod I had a mistake...I had a wire going from the bottom of R10 to the band of D5 when it should have been the band of D9. Could I have caused some damage here?
