Hardware trouble? Timing won't advance from 10 BTDC.
I'm using MSnS-E on a V2.2 PCB. I've changed the .ini file for Megatune to use -Extra. I'm attempting to use EDIS.
On the PCB, I've removed D9 and soldered a 1K resistor exactly as shown here:
I've connected pin 30 on the DB37 to pin 3 (SAW) on my EDIS module. I've got continuity between pin 30 and pin 3 on the EDIS module. In Megatune, the little timing gauge will display like it's advancing when I rev the engine, but I can see the timing stay rock-solid at 10 BTDC when viewed with a timing light.
Did I miss some steps in the hardware mods? Before I found this site I had been corresponding via email with a guy, who mentioned connecting the fifth pin of JP1 to pin 3 on the EDIS module. Another website mentioned jumpering XG1 and XG2 with a 1K resistor. I had tried both of these (in conjunction), and it would not advance spark.
Any insight would be greatly appreciated - I'm getting a little frustrated... been reading various websites over and over for hours and they all say the same thing, but it's not working for me.
Thanks,
Colin
Thanks,
Colin
Changed that, still not working. When I go into the config file, I can change it to MSnEDIS, but Megatune will not open. If I leave it at MSnS-Extra Megatune will open and run just fine, and I can open and adjust the "codebase and output" settings.
I'm a Mac guy through and through, so this screwing around with Windows is a learning curve...
Colin
Colin
MSnS-Extra is the one you want. MSnEDIS is a very early version - its all tied in Extra now.
If you done the EDIS mod - did you put the resistor on the LED and run the wire across?
If so, go into MegaTune, click:
Basic settings,
Codebase and output settings,
Set EDIS: to EDIS
Set FIDLE back to Idle control*
Set LED17(D14) function to Spark Output A
And there you have it
EDIT: Just re-read your post, realised you done option 'A' (I did Option B). So you may keep with the FIDLE set to Spark Output.
Have you done part 2 on that list yet?
Basic settings,
Set EDIS: to EDIS
Geared Ghia - UK Ford Escort 1800.
That's exactly what I did, then I changed the output from FIDLE to spark out. MS thinks it's advancing the timing - the on-screen gauge tells me it's advancing, but it's not actually advancing. I've got continuity between pin 30 (FIDLE) and SAW on the EDIS module, like I said.EstateAgent wrote:If so, go into MegaTune, click:
Basic settings,
Set EDIS: to EDIS
Bad module?
Colin
