another cop question
streetknight
Post by streetknight »
ok i have a ms1 v2.2 and i want to use this http://megasquirt.sourceforge.net/extra ... wheel.html is there any one else using it and if so did make your own protoboard? can you please point me in the right direction on setting on up?and also on my engine i have a second vr sensor for cams that would do waste spark how do i set that up. sorry im a pretty decent wrench but making circuits is some what over my head.
Keithg
Post by Keithg »
more info needed. What wheels are you using? What sensors are you using?
I am running COP 4 cyl on my driver. I use a 36-1 wheel with a hall sensor and a 1 per rev cam sensor also with a hall sensor. I had to make a daughter board for the second input and 4th output. My input conditioner for the second input is on my web page.
http://www.wideopenwest.com/~kgrider/sa ... d_hall.pdf
For the crank wheel, I use the opto with schematic 2 from teh msns dizzy page.
http://megasquirt.sourceforge.net/extra ... -neg12.jpg
KeithG
streetknight
tring to use the stock 60-2 cranks wheel, tring to use the vr sensor it came with.
Keithg
Post by Keithg »
you will need to get some prototype board material and solder up a circuit similar to the v3 vr circuit. there are some expansion boards sold on here from time to time. ask around.
for wasted spark, you need only a crank wheel. for cop you need a crank and a cam sensor.
keithg
Johan O R
Post by Johan O R »
Hi im a newbee an i have bought a MS V.3
My car:
Subaru Legacy 2.0 turbo 91´, Have COP ign. and i want to keep it.
so my Question is:
There is only 2 ign. output on the MS (Is it setup as Wastedspark -COP)?
Were do i connect the cam sensor on myboard??
Johan O R
Fastest95PGT
Post by Fastest95PGT »
Johan O R wrote:Hi im a newbee an i have bought a MS V.3
My car:
so my Question is:
Johan O R
Starting a new thread would probably get you a better response rather than going off topic in this one..
Here's a link to the cam angle sensor circuit needs.
Here's a link to the COP or wasted spark board modifications. Go to the "Driving the coil(s)" section of the link.
1995 Ford Probe GT ~ Megasquirted & Boosted
275whp/242wtq @ 5.5psi ---- 317whp/287wtq @ 8.5psi
^^^ (thanks to MSnS-E and dyno tuning by me!)
2003 GSX1300R (Hayabusa)
