WB o2 reading opposite since msns-e was added
95roush
Post by 95roush »
Hello everyone, new to this forum, hopefully I can help with something
my problem right now is that when I run MT and plug in the stim, when I adjust the pot clockwise, the AFR goes all the way rich, and the bar at the bottom reads lean. is there something I missed or is that how it should be?
I have the lc1 and msns-e firmware, also setup for tfi.
thanks
keithmac
Post by keithmac »
You can swap the bar around by editing the .ini, as long as the AFR guage is reading correctly you don`t have a problem.
Squirted VW GTI 16vG60 mk2
95roush
Post by 95roush »
the afr reads backwards to the stim input, but the bar reads correct, at full CW I read lean on the bar, rich on the afr gauge.
thanks, I really appreciate everyones time and help with the megasquirt
