Problem using output3 as an output
jassem99
Post by jassem99 »
Dear all,
I was hoping to use output3 to trigger a water mist setup on avehicle using MAT and TPS as inputs. On the stimulator, that part works (i.e. using source of output3 = output1+source does indeed combine MAT and TPS inputs). The problem is that the output from output3 (pin 15 of U1 after removing R1) is not an on-off output, but rather PWM-ish. The green 'LED' on megatune flickers randomly, and I confirmed this PWM-ish output with my scope.
Another problem is that the delay function of output3 doesn't seem to make any difference, and I was really hoping to use that feature.
Code is 029q2, PCB is v3. Anyone have any output3 experiences? Output1 and output2 work just fine as on-off switches, but they won't do delay or dual inputs like output3 seems to be able to do. Thanks for any suggestions.
Basil
In what way is it working on the stimulator?
jassem99
Post by jassem99 »
jsmcortina wrote:In what way is it working on the stimulator?
On the stimulator it gives a short pulse of voltage every few milliseconds. very much like the output on the FIdle pin.
Very off topic, but another problem i found today was that the overboost function does not work as i expected. The car kept boosting past 160kpa even when i had the hard cut limit set to 110kpa.
Basil
Karl
overboost
Post by Karl »
If youre flowing more exhaust than your waste gate can handle, then you will get overboost, even with MS working right.
Please post your MSQ
