Wonder wich is better?
Coil Internal Construction: Silicone
Maximum Voltage: 45,000 V
Turns Ratio: 75:1
Primary Resistance: 0.500 ohms
Secondary Resistance: 8K ohms
Peak Increase in Energy vs. OE: 10%
Peak Increase in Voltage vs. OE: 9%
Peak Increase in Arc Duration vs. OE: 6%
Peak Increase in Current vs. OE: 8%
OR
MSD
Coil Internal Construction: Epoxy
Maximum Voltage: 40,000 V
Turns Ratio: 80:1
Primary Resistance: 0.350 ohms
Secondary Resistance: 7.8K ohms
Inductance: 4.2 mH
Diego
PS: Want to run this setup but not sure wihc of both will handle betetr the spark output with my MS I 2.2 with extra code and VR sensor 60-2 wheel.
Accel vs MSD 2 tower coils
BMW 325is Turbo E30 (m20b30) MS II Extra code X.X (13 or 14) Beta 3.0v board - 2.25MT
