MS1, V3 board, MSnSE 29q2
Can anyone confirm if the wheel decoder pin at the CPU actually triggers on the leading or trailiing edge of the incoming pulses ?
See the LS1 thread for more details but essentially I have a 5V conditioned square wave signal fed from the crank sensor that is suitable for connecting direct to the CPU input pin but it needs to trigger on the trailing edge of the pulse. If the CPU triggers on the leading edge I'll have to invert the signal.
The trailing edge is a consistent, evenly spaced pulse train, the leading edge varies in position as the teeth of a mix of widths so I can't really trigger on the leading edge.
Quick wheel decoder question....
MobiSquirt - iPhone app for Megasquirt and Megajolt
It Runs !!! 3.9 V8 MSnS Extra
http://www.msruns.com/viewtopic.php?t=5106
5.7 Corvette V8 MSnS Extra
http://www.msruns.com/viewtopic.php?t=20094
The ~IRQ pin triggers on the falling edge. The second trigger is software configurable.
Should have just asked you in the first place James
Thanks, that makes life easier !
