V3 idle control with 2 wire bosch not working
I'm running msns-e on a v3 board and have just modified it to use the idle control valve. I am getting 12v at the valve but when i measure the voltage across the pins I only read 0.5v. Does this mean I have done something wrong on the ecu? I have tried to alter the settings but the voltage does not change, nor does the valve show any signs of life (it was working fine on the standard ecu). According to the help I should run the algorithm as B&G on/off not fielding PWM, is this correct? Does anyone have the settings required for a Vw Golf 8v lump, either in warmup or closed loop? I'm running 2.25b514
www.conrod.co.uk
20 valve turbo engine conversion, Mk2 Golf Gti
I have tried that already - no luck. Is it safe to assume there is a problem with the earthing side of it? Are there any tests I can do on the MS to help diagnose the fault?
www.conrod.co.uk
Hook it to the stim and see what it does. Try setting one of the gages in MT to IdleDC. That helps as well.
KeithG
Posted by email.
KeithG
Posted by email.
Thanks Keith - if only I had a stim....
www.conrod.co.uk
i had that problem with mine m8 i gave up in the end and run no idle controll and the car runns sweet as a nut ( just been setup on the rollers part boost though) i tryed for weeks to get mine to run but couldnt work it outbertelli_1 wrote:Anyone else got any ideas?
2.0 8v turbo 10.7 standing 1/4@136mph on m/s fastest mk2 astra 8vt in europe !!!
2.0 turbo tigra 10.1 standing 1/4 @ 145 mph with problems havent turned the boost up yet
Well, all I can suggest is to turn on an idleDC gage. Then try setting warmup mode and try different values of idleDC until you get it to regulate idle. If you get no voltage across the IAC, then you probably have a dead transistor (open) or a broken wire somewhere. Once you find out what value will allow it to regulate idle near your target speed in Warmup mode, then you can start to tune closed loop mode. If you can borrow/buy a stim, diagnosis will be easier, it definitely helps me. Which transistor did you swap out the 2n2222 for? Did you change the base transistor as well?
KeithG
KeithG
If you want someone to test your Megasquirt there are people in the UK that will provide the service. Phil R, Bill S or myself.
I use warmup only PWM idle on my car and it does exactly what it is supposed to do.
Thanks guys, i will try using the idleDC gauge. I used this guide http://www.megasquirt.info/ms2/IAC.htm#fidle when converting. If it still won't work I'll trace the MS circuitry and see if I can discover the fault.
www.conrod.co.uk
You are best to use the MS1 instructions when working on MS1 because MS2 does some things differently.
Fault fixed.
I have found the fault - I took a peek inside ms and found the TIP transistor had quite literally exploded. It seems although i used a mica insulator I didn't insulate the mounting bolt (no mention of this in the manual?) and it had earthed through the bolt and overheated. This has now been rectified and its working now. Well sort of anyway.....
www.conrod.co.uk
Re: Fault fixed.
Anyone have a good source for nylon bolts/nuts?bertelli_1 wrote:I have found the fault - I took a peek inside ms and found the TIP transistor had quite literally exploded. It seems although i used a mica insulator I didn't insulate the mounting bolt (no mention of this in the manual?) and it had earthed through the bolt and overheated. This has now been rectified and its working now. Well sort of anyway.....
Re: Fault fixed.
Most local hardware stores have nylon screws, nuts, washers, bolts and standoffs for cheap.Jon k wrote:Anyone have a good source for nylon bolts/nuts?
