Hello, I have big single cylinder (600 cc) engine with kickstart
and MegaSquirtnSpark-Extra ( Squirt and spark)
Is it possible to put "wait" time little longer?
It is now hard to start with kickstart because Mega shutdown after kick.
code is 029r
Single cylinder engine
Re: Single cylinder engine
Hello suvipiha
Sorry, I don't have your answer... but another question:
600c single kickstart?? is it a TT600 or old XT?
I'm working to FI an XT600E... so it could be interesting to exchange experiences...
best regards
best regards
If your bike doesn't have a battery, you'll need to add one to power the MS. It won't require much of a battery, since it won't have to power the ignition, just the ECU. One downside here is that if you're running batteryless, you also probably won't have a charging system, so you'll have to charge the battery some other way.
If you do have a battery and MS is "shutting down" after a kick, then you have some other problem.
'71 Porsche 914 2.2
'69 VW Squareback
'69 FIAT 124 Sport Coupe
'69 VW Squareback
Yes, I have battery etc. ( and it power ignition with Mega too)
Maybe shutdown is not correct word, I need little bit more time to kick again, before Mega stall
Maybe this is right place in code? (RPMPeriod)
---clip---
jCHECK_MMS: jmp CHECK_MMS
incrpm_crank:
cmp #$64 ; If RPMPH is 100 (or RPMPeriod =
; 2.5 sec) then engine stalled_________ <==== this 2.5 sec
blo jCHECK_MMS
cli ; ok, we can be interrupted again
stall:
clr engine ; Engine is stalled, clear all
; in engine
bclr fuelp,porta ; Turn off fuel Pump
clr rpmch
clr rpmcl
lda #00T
sta TCCycles ; If stalled then clear these 3 for Extra
sta TCAccel ; fuel during cranking
bclr NosDcOk,EnhancedBits ;
lda #$FF ; changed 025n, was zero. Causing problems with wheel pickup?
sta iTimeL
sta iTimeH
sta iTimeX
clr pw1 ; zero out pulsewidth
clr pw2 ; zero out pulsewidth
clr rpm
bclr cant_crank,EnhancedBits2 ; if we stalled we can
; crank again
TurnAllSpkOff ; macro to turn off all spark outputs
-----clip-------------------
---clip---
incrpm_crank:
blo jCHECK_MMS
stall:
; in engine
clr rpmch
clr rpmcl
lda #00T
sta iTimeL
sta iTimeH
sta iTimeX
clr rpm
; crank again
[quote="Fritz-XT600"]Hello suvipiha
Sorry, I don't have your answer... :( but another question:
[/quote]
No, it´s Husqvarna Te 610
More info:
http://www.bikez.com/motorcycles/husqva ... 0_1995.php
[/quote]
More info:
