Hey Guys,
I think my resetting issue is due to the car running very rich and backfireing under boost. Off boost it runs fine, but once I hit boost my AF goes down to about .6vdc! Super rich, off the scale. So, I just double checked my MAP settings, everything seems right. When the motor is off it reads 101kpa. I set the 4bar setting in the settings.ini file for Megatune, and selected 400Kpa Map sensor in Megatune. Before all this I was running the v2.2 board, but I upgraded to the v3 so I would have the flyback circuit and went for the 4bar map. So I copied all the settings from my v2.2 to v3 by hand and double checked everything. All settings are the same with the exeption of the Map sensor. Only thing I can think of is the scaleing is off somewhere. I've attached my VE map just for referance.
Help with settings when upgrading to v3 MS1 board and 4bar
Dodge 420a turbo (MSNS-E) | Nissan VQ35DE Twin Turbo | Nissan VQ30T
