i need info on the toyota 3rz-fe, 2.7 litre 4 cylender.
is the CAS the 3 wires coiming from the behind the alternator?
i cannot work out how to define the 3 wires on the crank angle sensor, or how many teeth it has, as it is very internal (middle of the block)
the engine also has a cam sensor, that i am also unable to define how it works, only 2 wires coming from it.
the engine has to run on wasted spark (no distributor) so any help on going about this, with these sensors would be great
thanks guys
toyota CAS help please
