When using 3 VB921s for WS...
When using 3 VB921s for wasted spark, I fused the +12v to the GM coil I am using. I have a 10Amp fuse inline with the 12v so as to add a little protection, but I've been starting the car maybe 10 times in the last few days I blew 2 10AMP fuses. It's always when cranking. It will hickup like its oging to start and then it won't - I get out and check the fuse and its blown. I swapped in a 20 AMP since I don't have any 15 AMPS and so far so good... but isn't the load of a VB921 theoretically 7.5A at max load? And thus, shouldn't 10 AMP be enough?
Ok sweet so I could prob put a 25 Amp in there to keep it happy? And in the event of a short or something, a 25 Amp fuse will definitely blow before significant damage to coils or MS happens yes?Mike_Robert wrote:On a stalled start, all of the ign lines *may*, though not always, go high and turn on the 921s until the stall detect routine kicks in and shuts off the FP, etc. 7.5 * 3, there ya go. 10 amp won't like it!
-Mike
I prefer to fuse each coil with a 7.5A Slo-Blo fuse for max protection. The coils can draw that much each but normally only milliseconds at a time for a lower average current. Besides, this way they can be used as a diagnostic based on which coil(s) popped, and the engine may continue to limp on the remaining cylinders to the next expressway exit...
FWIW,
David
FWIW,
David
An easy way to blow a fuse is to drop the clutch (by accident) at idle when running MS1/Extra wheel decoder. The stall code isn't quick enough to stop all coils from charging. A better implementation would have a "dead man's handle" so that it would enter stall mode faster.
I am thinking that the coils are blowing the fuse when my engine is not tunring off completely... the rpms drop to like 300 - 400 as you saw in my datalog due to my "run on" condition. This is probably what's blowing the coils, not cranking - that's my thought anyway - and then when I go to crank her up again the next time its already blown... sound about right?jsmcortina wrote:An easy way to blow a fuse is to drop the clutch (by accident) at idle when running MS1/Extra wheel decoder. The stall code isn't quick enough to stop all coils from charging. A better implementation would have a "dead man's handle" so that it would enter stall mode faster.
I'd fuse each coil individually but they are GM 3 tower coils, there is only one common +12v and 3 individual grounds (3 coils, wasted spark).
I've only managed it twice since last August and I was running a 10A fuse per coilpack (V8)
I would not be unduly alarmed, just take some spare fuses.
