It seems the wireing for my fan control is causing a backfeed which causes my MS to reset.
At least that's what I'm thinking.
I do have a scope, so where exactly should I scope on the transistor, and if there is some interference, would a cap between the legs of the transistor to ground help?
Thanks.
...Mitch
Fan control a suspect in resets.
...Mitch
Turbo'd Bmw M10 engine, 18psi, stock internals.
Using V3 board, with Ms1, HR code.
4 LS-1 Coils, 36-1 VR setup, and 4G15 (optical) Cas Retrofit for 2nd Trigger.
Did you fit the 1N4001 diode? Either on board to +12v or across the relay terminals.
