turbo timer
- fastereddie1011
yeah, I go by exhaust temp and it takes about 5 min. to cool down to 600 deg. where I like to shut it off.
My drinking team has a racing problem!
1989 ford probe lx. Turbo Fe3 swap
Approx. 300hp courtesy of Msns-extra. Sold the probe to some kid. Now its junk.....
Current project- 83 Chevy K10 w/TPI 383 MS2 ver3 board extra code 3.3.3?
Why not take the "after-run" relay out of the Audi 5000 turbo's. They are just a simple relay, with a capacitor that discharges after the ignition is switched off.
You can use it to kick on a after run coolent pump, with a temp. sensor. I've got this system on my car, it works perfectly.
EDIT:
Here is a pic of the after-run cooling system on the 5000 turbo's
It's all controlled by an afterrun relay that circulates coolent through the turbo backwards by a temp. switch in the head.
EDIT:
And for those of us without coolant in their turbo? (like many many aftermarket non-factory turbo cars)audibeanss wrote:It's all controlled by an afterrun relay that circulates coolent through the turbo backwards by a temp. switch in the head.
1995 Ford Probe GT ~ Megasquirted & Boosted
275whp/242wtq @ 5.5psi ---- 317whp/287wtq @ 8.5psi
^^^ (thanks to MSnS-E and dyno tuning by me!)
2003 GSX1300R (Hayabusa)
As has been mentioned in previous turbo timer threads, pressurized oil accumulators such as the type sold by Moroso (and buildable yourself from a common household fire extinguisher or exhaust pipe) can be used to supply cooling after-run oil to oil cooled turbo's. See here: http://www.guy-croft.com/viewtopic.php? ... dcd1364922 Racer's use them. Should be good enough for the street. Just not as blingy as a car running with nobody in it.And for those of us without coolant in their turbo? (like many many aftermarket non-factory turbo cars)
Nice thing is they also help while you run them - not just for cooldown. You don't have to install the solenoid pre-start system, but you must have a simple restricted one-way valve sytem to allow slow filling but fast oil release to the turbo. Many companies like McMaster-Carr sell them fairly cheaply.
Another option is the after-run oil circulation pump similar to the secondary water pump that audibeanss showed. I've seen them built from small EFI fuel pumps. Neither option will impress the girls as much as a turbo timer, but they are functional and safer if you actually need one.
Hope that helps,
David
turbo timer
"Here's how it works: when the coolant temp is above your set switchpoint, the output will go high and energize the relay coil thus connecting the 12V power to MS. So, even when you turn the key off, MS still has power and the car will continue running until it cools off below the set coolant temp switchpoint, at which point the output will go low, the relay will de-energize and MS will turn off."
Sounds good, EXCEPT, I would suggest a kill switch for the "unlikely" event of a cooling system failure in which the engine really is overheating. I had a rad hose blow on my car a few weeks ago, and this setup would have kept my car running until I could pull something to kill it.......
Daryl
Posted by email.
Daryl
Posted by email.
Re: turbo timer
The problem with this system is.... if the engine is running.. the coolant won't cool down.. it will probably even get a bit higher as there is less airflow to cool thing off. So the relay will never power off once trigger on.Daryl wrote:"Here's how it works: when the coolant temp is above your set switchpoint, the output will go high and energize the relay coil thus connecting the 12V power to MS. So, even when you turn the key off, MS still has power and the car will continue running until it cools off below the set coolant temp switchpoint, at which point the output will go low, the relay will de-energize and MS will turn off."
Daryl
Posted by email.
Miata '96, Tein Flex, HDHCDD, MS'n'Spark V3, Fuel only for now.
DIY turbo in mind
DIY turbo in mind
