well i though it was going to good its decided to play up now !!
if hold the throttle at set rpm say 3500 all of a sudden it will acc and dec for no reason and dump a load of fuel in all the time the throttles being moved its ok but as soon as you hold it in set position it will play up ive changed the tps and still the same
where else do i look for the problem
cheers
problems with tps
problems with tps
2.0 8v turbo 10.7 standing 1/4@136mph on m/s fastest mk2 astra 8vt in europe !!!
2.0 turbo tigra 10.1 standing 1/4 @ 145 mph with problems havent turned the boost up yet
dont matter ive sorted it turns out the ground i was useing was the same as the alternator ! but ive never had this trouble before and its been on 8 months so i moved the ground and away it went !!
