This is copied from a post in MS2...jsmcortina wrote:Using MS1/Extra, the 60-2 wheel and a single window dizzy as cam sync you should be able to run distributor spark or COP if you wish.
see http://megasquirt.sourceforge.net/extra ... wheel.html
I am going to use a 60-2 wheel and a single window dizzy on my 5 cylinder Audi 20V turbo engine. (I do not want to modify the dizzy to 5 windows)
I need some hints to get me started.
This is what I have configured so far – am I correct?
Codebase and outputs:
Wheel decoder:on
Fidle: Spark output A
Wheel decoder settings:
Base teeth: 60
2nd trigger enable: 2nd trigger
2nd trigger active edge: falling
Trig pos A=1
Trig pos B=13
Trig pos C=25
Trig pos D=37
Trig pos E=49
