MS1 hiccups...cured in MS2?
Just curious, I have a 4age 20v engine that loves to rev...but I've noticed running msns-e on MS1 that there are high rpm hiccups where the ms can't seem to keep up. Have these issues been solved with the MS2 or should I pony up and throw in a horribly expensive standalone ecu and retire the ms1 to my much lower revving nissan?
Could you provide some more details please, code version, ignition/fuel setup, MSQ, datalog etc.
There aren't any known issues like that with MS1.
there is a guy with a jet ski that revs a whole lot more than a 20v like yours or my partners though, and he seems to have no such issues. must be a signal problem or something...
On 7/13/06, jsmcortina <jsm@jsm-net.demon.co.uk (jsm@jsm-net.demon.co.uk)> wrote:
Posted by email.
My Success story http://www.msefi.com/viewtopic.php?t=8008
MS1/Extra at: http://megasquirt.sourceforge.net/extra
This post is at: http://www.msefi.com/viewtopic.php?p=130205#130205
Posted by email.
when you say high rpm, how high? i believe edis does have an upper limit quite close to the 8k redline or a blacktop.
On 7/13/06, Jason96SL2 < jason2483@juno.com (jason2483@juno.com)> wrote:
Posted by email.
It's running the latest msns-e code with a ford edis. I'm wondering if it's the edis that has the "hiccup" I'll see if I can catch it in the act with a datalog. Fuel is 450 cc injectors with a resistor box to make them high imp.
This post is at: http://www.msefi.com/viewtopic.php?p=130276#130276
Posted by email.
if you are using eids you might need resistor spark plugs, otherwise they might start missing on high rpm's
BMW, 1985, E30, 325i, 2-door, 5spd. Lots of custom work. Turbo build in progress: http://www.e30tech.com/forum/showthread.php?t=55733
