Flat Shift and 29Q2
2001dodgeneonrt
Post by 2001dodgeneonrt »
well I replaced the cpu but other problems have arose...
http://www.msefi.com/forums/viewtopic.p ... 840#132840
"MS is too much control" Stockneon
My Success Story...
2001dodgeneonrt
James is there anyway u can look into this? Both my friend and I have the same problem. Can u try and hook up a ground switch to js11 and turn on neon/420a and use stim as wheel. It should happen to you to. I really would like to have flat shift :) Thx alot!
My Success Story...
The flat shift code doesn't know or care what ignition mode you are in.
At present I cannot test as I do not have an MS1 chip on the bench.
dmarino
Post by dmarino »
I’m the friend with the flat shift issue. I have been running 25v2 (on 2.2) for quite some time and grounding jp1/4 for flat shift. It works great with 25v2 but when i upgraded to 29q2 it stopped functioning. I also made a new clean msq then i switched to 29q2. I have now switched back to 25v2 because i missed my ability to scare people :twisted:, well that and spin my tires hard in 4th :P. I’ve been following this thread and have experienced the same issues as 2001dodgeneonrt.
Could you post your 025v2 and 029q2 MSQs please.
dmarino
Post by dmarino »
I will do this as soon as i get home from work. Thanks for your help!
