well I replaced the cpu but other problems have arose...
http://www.msefi.com/forums/viewtopic.p ... 840#132840
Flat Shift and 29Q2
"MS is too much control" Stockneon
My Success Story...
My Success Story...
James is there anyway u can look into this? Both my friend and I have the same problem. Can u try and hook up a ground switch to js11 and turn on neon/420a and use stim as wheel. It should happen to you to. I really would like to have flat shift Thx alot!
My Success Story...
My Success Story...
The flat shift code doesn't know or care what ignition mode you are in.
At present I cannot test as I do not have an MS1 chip on the bench.
I’m the friend with the flat shift issue. I have been running 25v2 (on 2.2) for quite some time and grounding jp1/4 for flat shift. It works great with 25v2 but when i upgraded to 29q2 it stopped functioning. I also made a new clean msq then i switched to 29q2. I have now switched back to 25v2 because i missed my ability to scare people , well that and spin my tires hard in 4th . I’ve been following this thread and have experienced the same issues as 2001dodgeneonrt.
Could you post your 025v2 and 029q2 MSQs please.
