Im running (or at least trying to ) EDIS on my 95 toyota tercel (turbo swapped, other mods).
Anyway, I had it all wired up, and it actually ran and idled pretty good. My wiring was... well... sub par. I had a friend come over and we cleaned it all up, loomed it, etc. The only problem is, now it wont start. It stopped starting after we redid the ignition wiring. I have gone over EVERY wire, both related to the ignition and otherwise. I cannot find a wiring problem. Do you guys ahve any other suggestions on what might be wrong?
I have pulled all the plugs, and am getting spark. I didnt touch the wheel or the sensor. I am getting a clean RPM signal to MS. My injectors are firing. I put in new plugs. When it tries to start, it backfires and pops a lot, but doesnt actually fire like it should. I tried lowering the cranking pw, didnt see any real change.
Help?!
Rewired, now no start.
