EDIS Problem after rewire
I have a 95 toyota tercel with a td04l turbo, lots of other mods.
When I initially installed ms and EDIS (I had it running), my wiring wasn't very neat, so me and a friend went back and rewired everything. It looks really good now, all nice and loomed, but I can't get it to start. This problem sprung up after we redid the ignition wiring, but I have been back over the wiring about 100 times looking for problems, and can't find anything wrong with the wiring.
When I try to start it it pops a little, if I flood clear it backfires pretty bad. I pulled al lthe plugs, they are all sparking. Im getting a clean tach signal to ms, and the injectors are all firing. I didn't touch the VR sensor or crank wheel, so I am assuming the timing isn't off. I don't have a timing light handy, but Ill probably get one here pretty soon if I dont solve the problem. The symptoms are leading me to believe it is some kind of weak spark. I tried changing plugs, beefing up the +12v wires, adding/improving grounds... I just can't figure it out.
Im at the point where it makes almost no sense, and I am just staring at it at this point. Hopefully you guys can give me some new ideas so I can stop trying the same things over and over.
Thank you!
Thank you!
If it is sparking it seems like it can only be a couple things. The VR sensor is way off, which it doesn't sound like it could be. Or in the original install you had either the plug wires or the wires to the coils reversed. It is so easy to do. As a matter of fact my plug wires are reversed to compensate for reversed coil wires in my original install.
I can't think of any other way you could get RPM to Megatune and any spark out of the EDIS. If you had no spark or no RPM during cranking in Megatune you could start looking for other things.
