Switched to 029q and now my fuel pump wont prime?!
Hey guys, I just upgraded from Base firmware to the 029q on my v3 board... now my fuel pump does not prime when I turn the key to the on position... I reflashed base code and its priming again... any ideas?!@
??JediMindTricks wrote:I figured it out... I had loaded 029q2 instead of 029q, so I reflashed the MS and its working again!
There´s nothing wrong with the q2 there i think ?
I run q2 and i have full priming function...
What you should beware of is what some people experience, namely MSQ corruption when saving it and then flashing it in again after changing codeversion....
Peugeot 309GR1990 XU9JAZ(4cyl 1.9litre) 10.8:1 CR with 60-2 VR wheel decoding ,V2.2 card, singel coil and dizzy spark ,360cc 0 280 150 431 injectors. Msns-E hi-res 10d2 and E85(Ethanol) in the gastank.
Please do use 029q2 because 029q included incorrect temp sensor tables. Nothing in the code changed between the two.
Delete any copies of 029q you have.
