Does the spark timing depend on the Cranking RPM setting?
I tried to start my engine today and the timing was off. Now when I have checked things I found that my Cranking RPM was set to 300 and the real RPM while cranking is 200.
Using
Megasquirt and Edis, timebased crank timing
Cranking RPM and timing
Cranking rpm is the switchpoint at which MS leaves the cranking settings and goes into RUN.
Was your timing off in cranking or run ?
Peugeot 309GR1990 XU9JAZ(4cyl 1.9litre) 10.8:1 CR with 60-2 VR wheel decoding ,V2.2 card, singel coil and dizzy spark ,360cc 0 280 150 431 injectors. Msns-E hi-res 10d2 and E85(Ethanol) in the gastank.
During cranking the code uses the "cranking advance" setting to determine the advance when in timebased mode, or fires directly off the input signal in trigger return. So verify these settings are correct.
there are so many little details that makes big issuesDaniel Ahlin wrote:The timing was off by 180 degrees. Coil A & B wires where switched.
When I got that sorted it started directly and idles fine with lambda 0.78
