NO spark w/ Hei 8 pin distributor
lteeone
Post by lteeone »
Ok I'm running MS1 V3.0 29q with a stock hei 8 pin distributor in a 91 Firebird. It's wired as per the instructions and setup as per the directions. but I'm getting no spark even at the coil. I'm assuming the module is what fires the coil because I can't find anything that says otherwise. And I have the spark output inverted set to NO. Any help would be greatly appriciated.
-Scott-
1980 malibu 9.09 @151
1994 SS S10
2006 2500HD Duraslut
previous squirted rides 90 GSX eclipse MSnS, turbo'd SBC MSnS
