v3, msns-e, vr sensor, 60-2 decoder, single coil w/ dist.
I see on the wheel decoder page that the wiring example for a single coil shows pin 15 connected to ground.
I have my connector wired just like the external wiring picture with grounds on 19, and 7-11. Is this just an extra pin to get more ground continuity from, or am i missing something?
One more: The wheel decoder page says to jump VROUTINV to TSEL and it shows the setup window in MT with inverted set to "no". I ordered my v3 from protocar and told them im using msns-e with vr sensor. They jumped TSEL to VROUT. Does this mean i need to select inverted "yes"?
What is the correct setup with decoder and single coil?
Thank you so much for your time and help!
-Jesse
M5 Turbo, IgnOut ground? Inverted?
No! Don't do this. Please follow the instructions.Nickel_5000tq wrote: So jump VROUTINV to TSEL and says NOT inverted. OR
jump VROUT to TSEL and says INVERTED.
The spark output inverted has nothing to do with with VROUT/VROUTINV selection.
Doing what was suggested will result in incorrect timing and a melted VB921.
oups, right . its only the reading is inverted with the VRoutINV, not the spark output.
I run spark inverted and the other side of the coil is at +12V.
See:
http://megasquirt.sourceforge.net/extra ... wheel.html
See:
