Wireing my boost control fet in,
wondering if I can mount the fet to a grounded heatsink (no plastic screw)
also plan to mount a to-220 cased npn transistor for fan control onto the same heatsink, any issues with the ground?
Thanks.
Fet mounting, please read.
...Mitch
Turbo'd Bmw M10 engine, 18psi, stock internals.
Using V3 board, with Ms1, HR code.
4 LS-1 Coils, 36-1 VR setup, and 4G15 (optical) Cas Retrofit for 2nd Trigger.
If it is a TO220 the case of the FET is also a drain lead and the transisor case is the collector. In other words you cannot ground them. You need to use insulating hardware.
Got Knock? - see:
Viatrack Printed Circuit Designs (among other things) http://www.viatrack.ca
