Dumb question, but things have been changing a lot lately!
Where can I go to find older code variants? We put 029q2 on the turbo truck last night, and have an obvious misfire problem at WOT. Tach spikes. When we run 024s13c, no problem. I was curiuos to try out some different versions (026 perhaps?) and see if I can figure out if this is misconfiguration or ??
Wondering if we can still get older versions online?
thanks,
-scott
where do I find older code variants?
Squirted: it's easier to list the ones I haven't squirted. I need to do more motorcycle engines!
Just call me tonight. I must have 100 or so.
AW
Ps: Geek, did u see ?
http://www.ncs-stl.com/mike/Mike_Gateway_Spin.wmv
AW
Re: where do I find older code variants?
Does that truck run the missing tooth wheel decoder? If so, did you by chance try using the 024s9 style decoder?dieselgeek wrote:Dumb question, but things have been changing a lot lately!
thanks,
-scott
negative, we're still triggering off the "tach signal" the factory computer supplies. We're planning on converting it to the missing tooth decoder as soon as we get the tune sorted out... talking with Andy, I think I know what I did wrong. I'm headed to Jim's right now to try again with 029q2, will let you know what happens. Thanks ken!muythaibxr wrote:Does that truck run the missing tooth wheel decoder? If so, did you by chance try using the 024s9 style decoder?dieselgeek wrote:Dumb question, but things have been changing a lot lately!
thanks,
-scott
-scott
