Confused...X1,X2, IRLZ44,???
zero2x
Post by zero2x »
What do the number and lettering on the diagrams mean? I bought a MS1 V3 and plan to use MSnS code. I want to install all of the hard ware changes. Some for use right off the bat like electric fan control and Tach out, but use all the others later. This will be used on a 1.6 miata. I'll be using the factory wasted spark ignition for a while but I'm trying to go COP. I bought the kit already with 3 more transistors and resisters. I've alrady assembled the stim but I want to know everything I'll need for all the hardware changes bofore I even touch my MS. I would appreciate any help.
zero2x
Post by zero2x »
Oh, :shock: I meant right off the bat as a figure of speech not off the battery. Just had to clarify to avoid confusion.
zero2x
Post by zero2x »
nm
superchargingmachine
Post by superchargingmachine »
D1 = diode1
C1= Capacitor1
R1= Resistor1
etc......
X1 = a location on the board, if you look at the board with all the components installed you should see a X1, X2, etc... still visible.
IRFZ44 = a specific component
