Dual coil, wasted spark, 2xVB921 - getting erron on config?
Hi!
I'm trying to setup MS V2.2 (024s9 Extra, MT 2.24 b514) to drive Dual coil, wasted spark, 2xVB921 and VR sensor (VR conditionr cicuit build) on 4-cyl Suzuki bike engine.
But!
Im'getting error (fuel pump led on Stim flashes) when I select:
LED17 - Spark output
LED19 - Spark output B
How shoud I config MS?
Please help...
But!
Please help...
Ford Zetec Turbo in progress... MSnS-E, EDIS4, LC-1 ect. The engine is running @ 12Psi
What is the text error message?
Did you read the MS1/Extra FAQ?
From FAQ
Q - I have made some settings changes but when I turn it off then on it does not work any more. My fuel pump keeps turning on and off (flashing on stim)
A- You have made a configuration conflict.
Open up the Comms->Mini Terminal in Megatune OR open up Hyperterminal like you did when building the Megasquirt (see the Megamanual)
Ok guys,
I found my fault - didn't set triger possitions A and B in Wheel decoder
spend an hour on Extra site, but didn't find a clue.
I hope Extra code will be well documented soon..
Hey! It already says:
in the FAQ.
Plus, contributed documentation is always welcome.
in the FAQ.
