I have set up my MSv3.0 with MSnSE (29q) using 36-1 wheel & 6 VB921 to drive a twin plug 6 cylinder set up per the MSnSE site instructions.
I am getting no sparks and I noticed that during cranking, none of the front panel LEDs would light up. Are they still supposed to flash as the coil is triggered?
thanks.
spark output & LED 17/18/19 question
Please use 029q2 instead of 029q as the thermister tables are incorrect in 029q.
Yes the LEDs should flash in sequence. Do you get rpm in Megatune?
James,
Oops - yes, I'm using 29q2.
And yes, I get very stable cranking RPM.
I looked at the new plugs I put in - no sign of sparking but I can smell fuel. I also tried attaching the plug to the wire but not the car and I still dont see any sparks from the plug.
Any suggestion on where to start debugging?
thanks.
thanks.
ok - I have resolved the LED issue... a reload fixed that.
I have started a new thread in the Ignition tuning/troubleshooting section as it is definitely an ignition problem now.
The thread is here: http://www.msefi.com/forums/viewtopic.php?t=21071
