Im looking at getting a Megasquirt, and im plaining on running the msns-e software.
i own a 1993 mazda mx3 rs (1.6l sohc) and im a little confused about 1 aspect of the ignition connection.
My Distributor has 4 wires going to the top of it, from what i have been able to find out, my ecu controlls ignition advance. it has a external coil. i have been unable to determain what the 4 wires comming out the top do. im assuming a couple of them are for the camshaft position sensor, and the others are some sort of electronic advance.
any information on how i would go about wiring this to a v3 PCB would be really appreciated.
Thanks,
Bochek
New here. Got a question about electronic distributor
well a bit of a update, the 4 wires are for a hall effect sensor, (home and trigger) there is no mechanical advance inside the disty at all.
so basically. would i just wire up the hall effect sensor to the ms and then have it controll my MSD 6A and just have it advance the timing of the spark comming from the coil?
