Hi All
I've been tuning the MS for about 6 running hrs now and I wondered if some kind souls out there may be able to check my work to date to see if it looks like its on track?
My engine spec is a 1800 Ford Zetec-E with fast road cams, headwork and ITBs (45's).
Engine is roughly 170hp at 7000rpm, torque curve unknown but it comes on cam from about 3000 rpm onwards (cams are Raceline RL220's).
My datalog and msq can be found at
http://www.box.net/public/ckhl9ifi51 (datalog)
http://www.box.net/public/sjd93sr58p (msq)
The car feels sometimes a very little hestitant but as I'm driving I can't really tell why... Not an expert with the datalogs yet
Its when I'm pushing on a bit, typically around 2000ish RPM maybe 80-90kpa...
Obviously I've got big steps in my map - does that matter? (VE)
Also - is my MAP signal good enough or should it be smoother than it is?
Will
Can someone review my work to date?!?
